Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: upgraded alternator?
    38 Post(s)
    Quote Originally Posted by 26PSI View Post
    Picked up the patrol this morning.
    The old pulley had completely let go off the alternator shaft and wasn't generating any voltage at all. Hope it hasn't damaged my batteries too much.
    Yeah... the ZD uses a Sprag Clutch in the Pulley which can be problematic.
    Some people stick with a Clutch, some change out for a solid pulley
    Oct 2019
    Yeah, i decided to stick with the clutch after looking around a bit, reading and asking a few opinions.
    The original lasted 185k kms, Id be happy to get the same out of the replacement.
  4. The Following User Says Thank You to 26PSI For This Useful Post:
    Yeti's Beast (9th November 2019)
  5. #13
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    My original was still in the car after 15 years and 395,000k
  6. #14
    Patrol Guru paulyg's Avatar
    Ballarat
    When I replaced mine I went with a 110 amp with solid pulley, no problems after 18 months.
    2001 GU ZD30 Auto, EGR Valve blocked, Dawes and Needle Valve, 3 Inch Exhaust, ARE Scoop, Safari Snorkel, EGT and Boost Gauge, OME 2'' lift, TJM bar and brush rails and side steps, X9 Super winch.
