Results 1 to 10 of 12
Thread: GU7 Catch Can Mounting
    Patrol God Dhuck's Avatar
    Nov 2010
    Crap Weather State
    5 Post(s)
    Where is the best place to mount a catch can in my new trol? Will have second battery.
    Hardcore jack's Avatar
    Ballarat Area
    25 Post(s)
    Here you go Dhuck, made up a bracket and used existing bolts.
    Damn, no idea why it's upside down (must be iPad)
    Jack
  4. The Following User Says Thank You to jack For This Useful Post:
    Dhuck (16th October 2019)
    461 Post(s)
    I have seen them mounted between the grill and radiator. This was on the TI models where there’s zero room in the usual spot.
    Jun 2018
    24 Post(s)
    Not to derail this, but is that an Anderson plug for charging your dual battery via solar in the bottom right of frame?
    Nov 2010
    Crap Weather State
    5 Post(s)
    Yeah, I wont have much room around the firewall there I don't think. I think the ABS will be in the way.
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Have done 3 different CC installs CRD GUIV_what cooler and airbox are you going to end up with?
    Ballarat Area
    25 Post(s)
    Haven’t used it for charging, just use it for running the compressor.
    Jack
  10. The Following User Says Thank You to jack For This Useful Post:
    Cremulator (16th October 2019)
  11. #8
    Nov 2010
    Crap Weather State
    5 Post(s)
    Looking at HPD lid and series 1 cooler
  12. #9
    Jul 2017
    37 Post(s)
    My current install might suit ie: used an existing vertical plate brkt that comes off inner guard, adjacent to ABS (just fwd). Used 2x50mm pieces of angle(each approx 150mm long), mounted one angle vertical leg to side face of the existing plate brkt (ABS side) and on the horizontal face produced of that angle I bolted the other angle which formed a mounting brkt that had an inverted "U" profile section(used 2 pieces of angle so that the CC can be secured to one angle, the other angle attaches to the existing vertical plate brkt and then the two angle bolted together (may use nutserts for the latter). Took some pics tonight, can do more but not much room in my eng bay either.
    U can install fwd of this existing Brkt as well, but CC gets in the way when changing oil filter.
  13. The Following User Says Thank You to Bidja For This Useful Post:
    Dhuck (17th October 2019)
  14. #10
    Nov 2010
    Crap Weather State
    5 Post(s)
    Yeah, room is the issue. Not a lot available under there.
