Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: GU7 Catch Can Mounting
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Couple of more (Use FMIC these days):
    1. As mentioned, used same existing vert brkt adjacent to ABS but located CC fwd next to aux battery (Current CC install position is where large rotary switch is shown).
    2. With large JT cooler (same as CC ultimate cooler), installed CC under Fabwitz Airbox outlet pipe_would have been better to have place it at the current location. Rotary switch was problem then. Not prefered but have spare brkt for this.
  2. The Following User Says Thank You to Bidja For This Useful Post:
    Dhuck (17th October 2019)
    Jun 2018
    24 Post(s)
    Quote Originally Posted by Dhuck View Post
    Yeah, room is the issue. Not a lot available under there.
    If you haven't bought a catch can yet, have a look at the flash lube pro. They are a bit more compact than the provent.
    https://www.flashlube.com/en/product...h-can-pro.html
    This is what I mounted in my GU III.
  5. The Following User Says Thank You to Cremulator For This Useful Post:
