15th October 2019, 04:01 PM
Travelling Podologist
Removing Window winder handles.
If I post this here it may help me to recall how to do it next time, & if that fails I can hopefully find my post here to remind me!
In my electronic manual I could only find reference to removing the door skin for electric window models, nothing about manual winder handle removal.
I've done it before, & even made & carry a little hook tool to assist, but do you think I could remember just how the tool was used! Oh no sirree! Not for quite a while anyway.
Pushing the door skin in whilst pulling the winder handle out will create a small gap .... 2 or 3mm. With a hook made from thin but stiff wire it is possible to push the hook down into the gap to then pull the sprung clip holding the winder handle onto the shaft upward, releasing the handle.
And whilst I'm here ...... the little orange plastic 'plugs' on the back of the door skin, which push into hole in the door to hold the door skin in place - has anyone come up with a fix for when the damn things pull out of the hardboard/masonite of the door skin, tearing it?
15th October 2019 04:01 PM
15th October 2019, 04:21 PM
And most importantly, don't forget to lose at least one of the clips. If you do that, you know you're doing it / done it the same way you normally do it, well the way I do it.
The Following 2 Users Say Thank You to 10G For This Useful Post:
Cuppa (15th October 2019), Plasnart (15th October 2019)
15th October 2019, 04:59 PM
I am he, fear me
Cuppa
snip...
Yeah, can be a PIA mate esp if some water has got down there over time and softened the backing.
Use a trim removal tool and they won't usually pull out even if the backing is shitty.
Haven't done it on a Trol but in my younger days when Beer was more important than food or tools we used to pop out the clip and put a thin penny washer between the head of the clip and the trim.
16th October 2019, 01:37 PM
Australian door cards have a look at there ABS ones I fitted them on to my GU best things since sliced bread
