Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Electrical Water Temperature Senders - How To Test Folks?
    469 Post(s)
    Cheers Gents, was briefly chatting with Rusty_Nail mate today about possibilities and there could potentially be an issue with the Derale module and its chip thingies that do their smart farenheit on/off caper!
    Must say I did get a bit McGoogle excited buying it off a USA race mob years ago IIRC and wondered if its somewhat open improperly sealed undercarriage would survive completely different Bogan down under centigrades :-)
    rusty_nail (12th October 2019)
    469 Post(s)
    Thanks heaps @mudski mate for taking the time to kindly assist on site, greatly appreciated!
    We’re both in agreeance I think that I should have never bought the fandangle Derale unit in the first place dusty down under :-)
    Would anybody kindly know a best place to buy simple old school water sender switches from so I can make it more reliable?
    Trying to have fan #1 activate at 90C and then backup fan #2 at 95C for the heavier hill climbing summer stuff.
    mudski (13th October 2019)
  6. #13
    190 Post(s)
    Is that what the Derale unit did or are you looking for a different functionality MB? Have you confirmed the unit is unservicable? In hindsight maybe it should have been mounted in an IP rated box, but then again, a unit like this should be up to the typical duty its expected to be located within. I would drop the mob you bought it from and see if they can help with a switched module.
    MB (13th October 2019)
  8. #14
    469 Post(s)
    Cheers Philstar, I honestly just don’t trust this prick anymore mate!
    It does also, when previously working, have a spazzy both fans don’t shut off until circa 85C IIRC. That function smashes my alternator when not needed and I have to manually (like river crossings) flick off all power to reset its brain for some 120 secs.
    I’m over it, have achieved I believe the most stable running 6.5Chev certainly in Victorian mountains and some Yanky microMcChip is giving my nuffy noggin grief, fark it off I thinks :-)
  9. #15
    469 Post(s)
    Good old Tridon, never knew they had several hundred products throughout many catalogues for most blokes needs
    https://tridon.com.au/flipbook/65969
    PeeBee (16th October 2019)
  11. #16
    Jun 2018
    24 Post(s)
    Hey @MB, did you sort this out?
    I was just reading through the operating instructions for the redarc G52-BET and thought you could use the optional temp warning level on your redarc gauge to trigger the relay output and power on your second fan when it hits 95°.
    You should only have to buy a relay to test this out.
  12. The Following User Says Thank You to Cremulator For This Useful Post:
    MB (21st October 2019)
