Results 1 to 6 of 6
Thread: Cruise control Help
    Oct 2019
    Cruise control Help
    Hey guys and girls
    I ahve a question in regards to cruise control
    Car is a 2003 Zd30DDti
    The car was in an accident and some clown replaved the steering wheel with a series 2 wheel. They didnt install the cruise control switch
    The car has a led light near the heat switch that says cruise
    I cant findf any info regarding teh cruise control system in the workshop manuals
    As this car is drive by wire is there a separate cruise module or does it just integrate with the system if i install the switch?
    Any help please.. even if someone has that bit of teh manual!
    thanks
    You can download the full Service manual for your vehicle here http://www.nissanpatrol.com.au/forum...I-VII-amp-VIII
    I'm not familiar with the series 2 and 3 (had a 1 and a 5 myself) but would have thought that a separate LED labelled "cruise" meant you had an aftermarket cruise control which might explain the issue...
    Oct 2019
    Gu 1 had a toggle switch on the dash and only 3 buttons on the steering wheel.
    Gu 4 had a 4 button switch on the steering wheel.
    Im unsure about series 2 and 3
    Anyone got pics of switch and the inducator to know when its on or off ?
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    I've got a gu3 and the buttons are on the wheel with "cruise" indicators in the dash cluster. No separate led.
    Legendary happygu's Avatar
    Quote Originally Posted by find_adam View Post
    Hey guys and girls
    thanks
    My 2003 3L Di didn't have cruise control as standard, so I would guess yours was aftermarket like mine was when I put it on.
    The dealers back then would install the Autron Cruise Control Unit as a 'factory' fitment, and the separate LED is similar to the Autron unit I had so it could be that one.
    If you take a look and find an Auscruise module somewhere ( possibly under the dash if i remember right ), then it is definitely the Autron Unit
    Oct 2019
    Quote Originally Posted by happygu View Post
    Ill take a pic of the button and trace some wirez today
