28th September 2019, 12:05 PM
Zd30 crd turbo
Could someone please tell me what type of turbo is on the 2010 zd30 crd please?? Im mainly after what type of turbine outlet it has ( part where it joins the turbo to the exhaust dump pipe) i have done some searching and i keep getting gt2052v but some sites say only up to 1999 model and other say from 99 onwards.
28th September 2019 12:05 PM
28th September 2019, 01:35 PM
Hey mate.
Receipt from Nissan dealer when my crd was replaced says 769328 5001s as part number.
If you search that hope it helps you .
Mine was a 2009.
29th September 2019, 12:21 AM
Garrett M24 Housing and yes CRD is GT2052V Turbo mate. Turbo has 3 studs to dump pipe (8mm dia from memory) and if u are changing dump pipe be sure to use wurth nuts, they should be copper coated with a lock ring on top.
Reason: Thread read 8mm
The Following User Says Thank You to Bidja For This Useful Post:
Stump2jz (30th September 2019)
