Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: What do you recommend; water or oil temp sensor?
    472 Post(s)
    Sounds great thanks @Cremulator mate!
    Apologies can’t help, I cheated and had our mechanic install the Redarc in our wagon. Their downloadable install instructions should be available online somewhere to check threads hopefully mate.
    Cremulator (18th September 2019)
    472 Post(s)
    FWIW also @Cremulator mate!
    Our family TD42T near stock wagon and its current single 3in1 gauge was alarm bells set as per I believe hopefully solid advice found here and mechanics in agreeance as per below:
    Boost: 12psi running (alarm 13psi -ish)
    EGT: 575C alarm (Can hit this if we don’t drop down a cog labouring up heavy hotter hills)
    (Stock TD42T’s really do need IMO now an intercooler/tune)
    Water: 105C alarm (Unofficially to date have read 117C is max TD42 territory)
    Water temp wise, I have on previous trucks without aftermarket gauges nudged well into ‘H’ and they tough survived time after time.
    As O-TJ-O kindly mentions, the more in cab reactive information available is betterer IMO too :-)
  5. The Following 2 Users Say Thank You to MB For This Useful Post:
    0-TJ-0 (19th September 2019), Cremulator (18th September 2019)
