My current install might suit ie: used an existing vertical plate brkt that comes off inner guard, adjacent to ABS (just fwd). Used 2x50mm pieces of angle(each approx 150mm long), mounted one angle vertical leg to side face of the existing plate brkt (ABS side) and on the horizontal face produced of that angle I bolted the other angle which formed a mounting brkt that had an inverted "U" profile section(used 2 pieces of angle so that the CC can be secured to one angle, the other angle attaches to the existing vertical plate brkt and then the two angle bolted together (may use nutserts for the latter). Took some pics tonight, can do more but not much room in my eng bay either.
U can install fwd of this existing Brkt as well, but CC gets in the way when changing oil filter.
