Results 1 to 10 of 10
Thread: sub tank transfer pump
    Sep 2019
    hi all. hope someone can help.the transfer pump is dead.can i fit a cheap pump in there ?
    cheers and thanks jim
  2. The Following User Says Thank You to jamesmcjim For This Useful Post:
    MB (15th September 2019)
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    Quote Originally Posted by jamesmcjim View Post
    You can physically do it.. but you won't have any of tge auto-stop safety features and will need to wire it inn yourself
  5. The Following User Says Thank You to 0-TJ-0 For This Useful Post:
  6. #3
    Wot he said ^^^^
    but...
    If you want to avoid extra wiring, switches etc and retain the same features as the factory system you can add a high wattage shunt resistor at the Aftermarket Pump connection so the resistance seems the same to the Sub Tank Computer.
    Mine was a 3 Ohm IIRC.
    The factory resistance is in the manual, if you measure the new pump and adjust accordingly the system will work as factory
  7. The Following 3 Users Say Thank You to the evil twin For This Useful Post:
    0-TJ-0 (15th September 2019), MB (15th September 2019), mudski (17th September 2019)
  8. #4
    Jan 2017
    South Australia
    11 Post(s)
    Well there ya go. Learning every day. I'll keep that in mind.
  9. The Following User Says Thank You to 0-TJ-0 For This Useful Post:
  10. #5
    Sep 2019
    all very good. thank you for that knowledge.
    this is a top site
  11. The Following User Says Thank You to jamesmcjim For This Useful Post:
  12. #6
    Yeah, one of those things that can be done but not the simplest thing to do so most don't bother and just run a power wire and put in a switch.
    Ebay is a good source for a shunt resistor of a value and power rating (minimum 25 watts IIRC but will depend on the pump) that will handle the current. https://www.ebay.com/itm/25-50-100W-...r=452535670247
  13. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
  14. #7
    Sep 2019
    hi again.
    well i dont seem to be able to find there resistance for the factor pump .does anyone have that.if so it would be greatly appreciated.
    thanks and cheers jim
  15. #8
    hi again.
    What model?
    GU TD42 was around 2 Ohms IIRC
  16. #9
    Sep 2019
    its a y61 ute 1999 model with the td42 diesel motor.
    thanks jim
  17. #10
    thanks jim
    My last GU was a 99 Ute.
    Started life as a TD42 but was a 6.5 Brunny when I bought it.
    I've sold it now so cant check the brand/model but was around 120 LPH (similar to factory flow rate) low pressure jobbie and IIRC required a 3 Ohm resistor to fool the sub tank computer and pass the self test.
    The resistor connection failed one time and I had to resolder it out bush which was a bit of a PIA.
    The vehicle was owned by a wheat farmer so the pump was a bog standard one used on plant and equipment on the farm and might have been either a "facet" or "bosch" or possibly "AC Delco" but Facet rings a bell from somewhere.
    No matter what brand you may have to do a bit of trial and error to sort it out
