7th September 2019, 08:44 PM
MudRunnerTD
Madness. What a lot of stuffing around. Waste of time and money mate.
You need 50mm plus the floating floor or including the floating floor?
Graded Battens straight on top of the tiles. No brainer mate. The sound will be pretty solid as the Battens are straight on the slab rather than spanning.
If your really concerned just 20mm yellow tongue floor over 20mm Battens. Then floating floor. If you want to deaden it more out double thick yellow tongue.
Leave the tiles there mate. Pointless pulling the up. Straight over the top. Go.
I don't think you have read this right Daz. Or I haven't explained myself right. I want to lay a floating timber floor from this entrance and into the rumpus area. As it stands, the tiled area is about 25mm higher than the adjoining rumpus room, which is just concrete. I removed two tiles to inspect whats underneath. Well the tile is really thick, at around 25mm. Then theres another 25mm from under this to the concrete base. So when I remove the tiles the existing base is actually lower than the floor in the rumpus.
So I cant go over the top of the tiles.
MudRunnerTD (7th September 2019)
7th September 2019 08:44 PM
7th September 2019, 08:48 PM
Ok here’s a pic of the actual difference when I remove the tile. See how much lower it is.
7th September 2019, 09:04 PM
Moderator
mudski
How high is that? I can't really tell on my phone.
Check out my Toy -->
Rogue Dung Beetle
7th September 2019, 09:06 PM
Moderator
Looks like half a brick so your 50mm. So Yellow Tongue is 19mm board. Down on 30mm Battens will get you your 50mm. 100% batten it out mate.
Rogue Dung Beetle
7th September 2019, 09:59 PM
MudRunnerTD
The issue with battens is the sound and feel difference under your feet from one room with battens to the next room with a solid base. I helped a mate years ago do similar, while he was happy with the outcome, you could hear and feel the difference, as it was hollow under the foot.
But. Its worth thinking over. I will see how much it will be for half a cube of conc to do it and think about it.
7th September 2019, 10:21 PM
Moderator
mudski
Battens down on concrete will feel very similar to floating floor straight on conc. I walk on it all the time in customers houses. If your really concerned then 12mm lining boards as Battens then 2 x yellow tongue on top of each other is another 38mm of solid chipboard. Floating floor over that and it will feel and sound like conc.
Rogue Dung Beetle
Bidja (7th September 2019)
7th September 2019, 10:27 PM
#17
Moderator
I stamp my feet in houses every day to check for floor construction when determining if I'm walking on a slab l/ sub floor or Battens. You can tell if a floor has big Battens or small ones and you have to stamp hard to hear it. I really would by or be concerned here at all mate.
Rogue Dung Beetle
mudski (9th September 2019)
7th September 2019, 11:29 PM
#18
I prefer to fix T&G 19mm flooring to timber battens or joist spaced at 450mm centers. Another method for laying timber flooring over your existing tiles is to use ply sheeting. The sheeting is laid over the tiles to create a good surface for the timber flooring to be laid on. Thickness to suit desired finished floor level. The floorboards are then glued and nailed to the ply. Use a polyurethane sealant / adhesive like Sikaflex 11FC or what I have used is Bostic Seal N Flex1. Great for fixing plasterboard to masonry as well.
https://www.bostik.com/australia/Bos...ethane-Sealant
8th September 2019, 12:23 AM
#19
Moderator
Bidja
Yeah ply or Yellow Tongue chipboard works great. 450 centred Battens will be great straight on the concrete will feel and sound solid too.
Rogue Dung Beetle
8th September 2019, 12:41 PM
#20
@mudski to bring your low slab up and level to obtain common datum throughout maybe ARDEX K 900 BF could help mate (Ideal for levelling up to 90mm thick). Need expansion joint and recon use a polyurethane flexible adhesive between timbers/ply etc.
https://ardexaustralia.com/product/ardex-k-900-bf/
http://cdn.ardexaustralia.com/pdf/pr...0Datasheet.pdf
