Results 11 to 20 of 25
Thread: Looking for advice from the gourou's out there
    Expert First Pooy's Avatar
    Mar 2018
    22 Post(s)
    Quote Originally Posted by First Pooy View Post
    I am convinced I have been sent the wrong bar from superior and here are the pics
    If thats the case measure centres and compare to the factory bar. In reality it should end up about an inch or so longer than the factory bar to re-centre everything
    Again, how did you go with your pinion angle. It still looks like it's rolled a fair way forward
    96 GQ coil/Cab
    08 G6eT
  4. #13
    Mar 2018
    So far the mesurments say it is right but I will finish the front end first and recheck it again and if I go the lower control arms eventually it would push the back wheels back again and change the tail shaft angle also
  5. #14
    22 Post(s)
    If the measurements say it's right, then it'll be right.
    Didn't you get adjustable uppers? Adjust them to set the angle
    96 GQ coil/Cab
    08 G6eT
  6. The Following 2 Users Say Thank You to Ben-e-boy For This Useful Post:
    mudski (7th September 2019), rusty_nail (7th September 2019)
  7. #15
    Mar 2018
    Yeah I got adjustable upper control arms but the wheels are very close to the gaurd so longer lower will give me more room and better stability/flex
  8. #16
    Remember to leave all bushes loose enough to settle in the right position once the vehicle is on the ground. This allows you to tighten them so it doesn't put undue stress on them when flexing.
  9. #17
    461 Post(s)
    Yeah you can clearly see in the last pic the diff is pointing down too much still.
    Just for shits and giggles. You haven't got the control arms in arse about? As the bush ends are angled so there is a left and right to them. Just thinking if they are arse about it may be stopping you from correctly adjusting the panhard... Dunno...
  10. #18
    Advanced tryan277's Avatar
    May 2016
    Melbourne, Southern Burbs
    Do not have a answer to your question, but the orientation of your shocks, is there a reason why you installed them the way you have?
    To me they are upside down. Maybe it does not matter.
    Cheers Trevor
  11. The Following User Says Thank You to tryan277 For This Useful Post:
  12. #19
    461 Post(s)
    Quote Originally Posted by tryan277 View Post
    Cheers Trevor
    The pics are just upside down. Lol. They are the right way mate. The blue boot is covering the shock absorber shaft.
  13. #20
    Mar 2018
    Yeah I left everything lose until the patrols full wieght was on them and then torqed them up.
