Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Looking for advice from the gourou's out there
    Expert First Pooy's Avatar
    Mar 2018
    I put a superior 3 in lift kit in and all sorts of wierd things are happening but first my panhard is at full adjustment and I still need about half an inch to line with chassis, I rang superior and they can't explain it espeicaily with having a 3 inch lift I should be winding the panhard the other way, they did suggest taking one of the lock nuts out but that did'nt work the only thing that I can see is cutting the new bar down to get more adjustment
    hey mate, Goro here
    any chance you can upload a pic of your panhards etc? pics tell a thousand words, might be something super obvious.
    Mar 2018
    hey mate, Goro here
    Yeah I can take a pic but I found the problem the sent me Gq panhard that is striaght and I have Gu diffs and the panhard in the pics has a bend in it, I did tell them that I had Gu diffs and I was told that there is no difference in the kits appart from the connection at the steering box well that is'nt so apparently
    @Rossco @MudRunnerTD are a few of the members on here running gu diffs on gqs i believe. they might be able to give you some direction?
    All front Panhard rods have a curve in them whether it be GQ or gu. Is the rear one straight?
    Mar 2018
    My rear one is striaght at the moment but the Gu rear panhard on there site has a bend in it and it is for utes and wagons pre 2000 and mine is out of a ute
    22 Post(s)
    Quote Originally Posted by First Pooy View Post
    Got any pics? Honestly, cutting the bar down is stupid. You've done something wrong .
    Also, how did you go with the pinion angle
    96 GQ coil/Cab
    08 G6eT
    461 Post(s)
    Can you provide links to the exact ones you bought? If the rod are adjusted all the way in they would be too long that means. So you might have gotten a longer bar to suit larger lift than what you have?
    Just thinking out aloud here....
  10. #9
    Mar 2018
    I am convinced I have been sent the wrong bar from superior and here are the pics 20190907_143036.jpg20190907_143025.jpg20190907_142957.jpg20190907_142946.jpg20190907_142925.jpg20190907_142859.jpg
  11. #10
    Panhard between GU and GQ are interchangeable though. I have a GQ panhard on mine with GU diffs and it is fine.
