Results 1 to 4 of 4
Thread: Suggestions on how to protect my tint
    Expert First Pooy's Avatar
    Mar 2018
    When I get my new tint done I don't want it damaged by things moving I was thinking of some kind of light mesh but I have found nothing on the net and most likly will have to get something custom made grrrr
    Nov 2019
    If your talking about things moving around in the rear of the vehicle, you can get some clear Perspex which if cut tight enough it will sit under the rubbers. I have done a similar thing with mine.
    i used some perforated black film, you cant see in but you can see out if you want.
    I cant turn that far, cheap as chips in eBay
    juzzs8 (7th December 2019)
    175 Post(s)
    I applied static cling shade to the rear compartment windows and doors. Can't look in but can just look out. I done it to sun protect the back from heat etc, but it also acts as a physical tint protector I suppose. Very cheap from Autobarn.
    https://www.autobarn.com.au/streetwi...00x450mm-black
