Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: TD42 EGR block and inter cooler butterfly value
    Sep 2019
    Talking TD42 EGR block and inter cooler butterfly value
    Hi All
    New to this Forum
    We have a 2004 Patrol with a TD42 intercooled - 200,000K
    Its been a very reliable and solid 4WD, we bought nearly 10 years ago at 96,000KM and its rarely missed a beat. Best vehicle I have owned.
    I'm not that mechanically minded, so I'm searching for some answers out there.
    I'm seeking advice from anyone who has correctly blocked an EGR value on such an engine. I've had a block put on the EGR value when we purchased a large caravan to help boost performance and fuel economy. Seen a slight benefit. Someone (who claims to be 4.2 expert) the other day said to me that we also need to disable the butterfly value in the intercooler that is connected to the EGR system somehow. With the EGR blocked the butterfly value may be coming on and starving the engine of air flow. I've spoken to my normal mechanic and several other mechanics in town and they don't know anything about this butterfly in the intercooler procedure. Some of the forums I have been reading do state the butterfly value needs disabling as well - so maybe there is something required here. Can anyone advise what this butterfly value does?
    I too have had what seems to be heat issues towing under stress, either hot weather or up hills. I'm told its normal for the factory gauge to rise to a fair way up towards the max mark, first time we towed the caravan up the Adelaide Hills the gauge rose very quickly towards the max mark, scared the shit of out me, but was a very hot day as well. Once we got out the climb it fell back to normal. Does a bigger radiator help ? or just add more water to cool down !
    Another issue I'm having occasionally is "over run" after switching the car off where it knocks and bangs, sounds like its running half the number of cylinders - seems the fuel pump isn't fully shutting of the engine. Either have to turn on the key again, give a rev and switch off again, or stall the engine by dropping into 4th gear. I'm told its a common fault with the TD42 - but try telling my wife what to do this happens! Would like to know exactly what this is and what it might take to fix it.
    Finally can anyone recommend a mechanic or service center that specialises in these TD42 engines and knows all the tips and tricks?
    Thanks J
    Legendary
    194 Post(s)
    Welcome to the forum, I am sure all these issues have been covered at some time. Have a read of this current investigation with a few members re overheating on the TD42 and thermostat swapping. Do a search on the site for other issues.
    http://www.nissanpatrol.com.au/forum...er-Thermostats
  4. The Following User Says Thank You to PeeBee For This Useful Post:
    MB (1st September 2019)
  5. #3
    472 Post(s)
    Welcome aboard mate!
    I’m personally a big fan (pardon the pun) of keeping our stock TD42T with cleanest 100% OEM parts.
    A first quick step test for your system is the old directional pizza box roll trick to firstly rule out your viscous hub is locking up correctly when hot and needed.
  6. #4
    Sep 2019
    Thanks PeeBee and MB. I will have a look.
  7. The Following User Says Thank You to langcom For This Useful Post:
  8. #5
    Jun 2018
    24 Post(s)
    I'm curious @MB, does that test just tell you which way the fan is spinning and therefore if it is blowing or sucking air??
  9. #6
    Legendary
    194 Post(s)
    Its to check the resistance of the fluid coupling and if it is shearing or not driving the fan correctly.
  10. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    Cremulator (1st September 2019), MB (1st September 2019)
  11. #7
    472 Post(s)
    No sorry mate, just meant to say hold the roll in the direction in my picture so it lightly skips on the blade tips instead of the other way jarring back in your face and shattering your fan :-(
    It tests (when hot) that the fan is locking up instead of still being in say cold half spinning friction fuel economy action if that makes any sense?
  12. The Following User Says Thank You to MB For This Useful Post:
  13. #8
    472 Post(s)
    What PeeBee better said :-)
    Typing same time apologies!
  14. #9
    472 Post(s)
    Quote Originally Posted by langcom View Post
    Most welcome mate, hope it can help and more so hope it’s an easy fix for you!
    Take care, stay safe!!
    EDIT: When you get a chance mate, pop over to the introduction section to say G’day and meet the NP.com.au crew, great folks
  15. #10
    Jun 2018
    24 Post(s)
    Ahh, thanks for the explanation guys, that makes more sense now.
  16. The Following User Says Thank You to Cremulator For This Useful Post:
