12th June 2011, 06:28 PM
2.8 timing marks.
hey all i have ripped the head off my gu because of blown head gasket and now time to put it back together i was wondering when puttin in the timing belt is there any specific specs to where the pump,cam and crank line up or do i just put the pulleys on the marks and thats that? and does anyone know what the inserts that go into the head that the injectors sit in actually do ?
all info will be appreciated. cheers ashley
12th June 2011 06:28 PM
12th June 2011, 06:59 PM
If you down load the "1998 Nissan Patrol Manual" the timing marks that you need to line up are shown on page EM19 (page 99).
The injector inserts are a gasket to seal the injectors to the cylinder head.
Tony
12th June 2011, 07:10 PM
Hardcore
When you put the harmonic balancer on, make sure you loctite it.
When you think you have the timing right, turn the motor over by hand 4 complete turns to double check.
This is best done with glo plugs out.
4th November 2017, 03:59 PM
doing same thing but no manual
