Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Scenic Rim Adventure Park
    Expert scotty83's Avatar
    Apr 2011
    Hillcrest, QLD
    Took a trip here on the 22nd July. Still very much under construction for people that like their paint work. Would be interesting in a bush beast as some of the new tracks look good but are still surrounded by a lot of pin striping material. Obviously still not as big as LCMP but a lot closer for the Southsider's.
    Facilities are available and extra facilities are in the works.
    Park is divided into two "Main Tracks" by a large gully. These then split into off shoots, only issue I had with these is that due to the hills most of these tracks don't loop back causing you to back track to get out. I can imagine some of the tracks will be very different after some rain.
    Look forward to any updates people have on this park as it expands
    Scotty B | Take it Off Road or Take it Back
    3.0L GUIV 2005 - TIG Welded Intercooler, NADS, Redarc Dual Battery, Additional rear power socket, 2" Lift (Ironman constant load foam cell), Electronic Trailer Brake Controller, Steel Bullbar, 12,000lb Winch, UHF
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Steve ( 04OFF ), I have removed your maps due to change of address
    Todd
  4. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    04OFF (1st August 2012)
