Results 1 to 8 of 8
Thread: Whining noise in 2014 Y61
    Jul 2015
    Camden NSW
    6 Post(s)
    i have an issue that is starting to annoy me. If I sit on 100 - 105klph I get a loud whining noise. It happens when cruising and goes away when under load. It's not a tyre noise, and I suspect that it's been happening for some time, but was not noticeable when I was running 33" muds. Now that I've gone back to the original mag wheels and standard original tyres, it is noticeable. I've recently changed all oils except the auto trans, and the noise remains. I suspected the belt tensioner, as I changed one at about 40thou, and now I'm at about 80thou, so I'm thinking ones due. Unlike the first replacement which screamed at idle or at reves, the current one doesn't.
    This noise is different, it sounds like a diff whine, although there was no indication of wear when the oils were changed. I was thinking of doing a auto service just to eliminate that possibility.
    Any ideas or similar issue from others?
    Uni Joints can make odd noises under no/minimum load... esp if the vehicle has been modd'd so the diff pinion and transfer output shaft angles aren't right
  4. The Following User Says Thank You to the evil twin For This Useful Post:
    PeeBee (21st August 2019)
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    If it changes tone when not/under load it sounds drive line related. Wouldn't expect the belt tensioner would change tones regardless of engine load, just engine speed.
    22 Post(s)
    I had a bad whine in my GQ years ago. It went away when I decided not to see her anymore.
    96 GQ coil/Cab
    08 G6eT
    sunshinecoast
    3 Post(s)
    possible a boost leak at one of the joins between the turbo and inlet , including inlet manifold ( they sometimes warp ) also check the egr pipe and connections and the intercooler . others have had problems with these items , if you search the site you might be able to find posts of how others were able to find and test for leaks . look for any telltale signs of slight oil leaks
    Expert Deano2506's Avatar
    Apr 2017
    Hobart,tasmania
    🤣🤣you beat me to it...well done
  9. #7
    Aug 2019
    Cheers thanks, ill have a look.
  10. #8
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    My car has a similar noise but it stops when the wife gets out
