Results 1 to 10 of 10
Thread: GQ full rebuildt
    Aug 2019
    GQ full rebuildt
    I have re-built the whole engin and ran for 30 min and shut down, then when re- started only ran for 5 seconds, cleaned all pluming and filters, stayed the same, took to local guy to fix and he priced me $2200, few days later he asked me 5K , went back an pick my truck up and cost me $700 to get a half dismantled pump with loose parts. Will buy myself a injector tester and see what I can do with my Pump????
    330 Post(s)
    Hi mate, welcome. what engine is it? what country are you in?
    Patrol God Dhuck's Avatar
    Nov 2010
    Crap Weather State
    5 Post(s)
    Welcome to the forum mate.
    Aug 2019
    Thanks Guys, Living in Adelaide SA. TD42 Non turbo, made it turbo(all inside) from silver top motor.
  6. #5
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    A brand new pump would only cost you $2k-ish. Don't think it's something you can fix in your back yard.
    If you want to get it fixed, take it to mtq at recency. They should sort you out. I think they also do new/built pumps. Otherwise I would recommend UFI in WA. I reckon they priced a 250hp 11mm pump at about the $2,300 mark. Few other reputable pump builders out there but I had good dealings with UFI - plus the pump the send is brand new.
    2003 GU TD42 with a few extra ponies
  7. #6
    Aug 2019
    Thanks, will do injectors first and remove pump for repair.
  8. #7
    330 Post(s)
    Quote Originally Posted by stig View Post
    https://youtu.be/Bp3j0Ga-3k8
    First run before problems started with pump or injectors
    Taken from your other thread mate. Consider starting a thread in the general chat of mechanical chat rather than another intro thread, it will get lost here.
  9. #8
    330 Post(s)
    I see that the air-filter is not hooked up and there is a Vac hose hanging off in the video. Is it all back together, sounds like t is running pretty good in that vid.
  10. #9
    Aug 2019
    Yes, all togeather but will start and then dies.
  11. #10
    Jan 2017
    South Australia
    11 Post(s)
    Checked your filter and fuel feed lines aren't sucking air?
