Page 7 of 14 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 140
Thread: TD42 - All Variants Aussie Water Thermostats
  1. #61
    That sounds about right mate, how many car manufacturers have you seen where emmisions get propped up at a cost to performance.
  2. The Following User Says Thank You to rusty_nail For This Useful Post:
    MB (3rd September 2019)
    460 Post(s)
    I know with mine, until the engine reaches operating temp it will puff out a lot more black smoke than usual. My last snow trip past Marysville, the water temps got down as low as 45c on the downhill run and then along the flats out of there it was like puffing billy until the water temps got back up there. The weather is warming so I wont even bother with putting a hotter stat in. But then again, Im curious to see if a hotter stat will benefit or not during the warmer months.
  5. #63
    472 Post(s)
    What is a TD42’s official operating temp Mark mate? That was one of my first queries I believe?
  6. #64
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    This goes along with what I was thinking though.. surely even if you put a hotter stat in the cooling system will still work at the same efficiency.. i.e. you would have the same chance of overheating with a 76deg or 88deg stat.
    Yes the water gets warmer in the engine.. but it also has more chance to cool in the radiator..
    I've never tested this but it makes sense in my head.
  7. #65
    460 Post(s)
    Water temp? What ever the stat is rated at would think.
    Not so much of having more chance once the water cools to the stats range it will shut anyway. So a higher rated stat means it will shut earlier when trying to cool down, only cooling the water in the radiator and not the engine. IF the stat is shut that is. But by then its cool enough anyways.
    confusing shite...
  8. #66
    472 Post(s)
    I think I posted earlier that my 6.5Chev manual clears states its operating temp (water) as 88C and its max at 125C before catastrophic failure I guess:-) It also states other temps like oil etc...
    I believe I have read unofficially somewhere that a TD42 max operating temp was something like 117C but buggered if I have been able to find Nissan’s operating temp?
    I believe most tropical TD42 drivers with 76.5C thermostats find in reality they run full open and in the 80’s somewhere as a minimum and much higher under demanding conditions anyway?
  9. #67
    460 Post(s)
    Ah ok... Yeah without looking I think it is 117c is their danger level. I've had mine past that. Dragging the camper through the snowy mountains, crawling up massive inclines near Corryong in 44c temps. Wasn't fun.
  10. #68
    sunshinecoast
    3 Post(s)
    my brother bought a diesel vw last year and it sits on 99-100 degrees and gets 5 lph . i think that the older cars engines being bigger and not as efficient put out more heat and keeping the engine temps low ( 76d ), in hot ambient temps would make the car more comfortable to ride in and help the air con do its job. i have a mate with a old xp falcon ( no air con ) and it got uncomfortably hot to ride in , so much so that he put insulation on the inside of the firewall and it helped quite noticeably
  11. #69
    472 Post(s)
    Safe storage note here for oneself look back folks.
    Ambient early spring nightfall temps here have happily risen quite a bit :-)
    A/C fan on demisting/cooling engine bay at idle for 30mins seems to have come up to 87-89C ping pong compared to frigid nights prior pictured before at 82C.
    A/C fan off for a further 20mins and seems to ping pong between 88-89C.
    Gave it a good flogging this afternoon up our local test hill to reach 550EGT’s and scored 93-94C at best before coasting down the other side back to 87C amazingly quickly.
  12. The Following User Says Thank You to MB For This Useful Post:
    mudski (4th September 2019)
  13. #70
    472 Post(s)
    Finally some half decent weather down here earlier today to record some more TD27 88C winter thermostat findings in the old TD42Test.
    As per last highway runs record it appears to have now increased all numbers by approximately 1-2C.
    So previous range of 80/90/100/110kmph with temps of 88/89/90/91C have today now jumped to 89/90/91/92C and a sneak into 93C at one short blip up and back.
    Off highway/freeway gave it another top flogging 575EGT’s up our test hill and did manage to score 96C briefly.
    Not too stressed at this stage as previous 88C TS pot tests showed full open wasn’t until 98C.
    EDIT: Idle has now come up to 89C too IIRC
  14. The Following 2 Users Say Thank You to MB For This Useful Post:
    0-TJ-0 (21st September 2019), mudski (22nd September 2019)
