15th August 2019, 07:38 PM
Patrol MQ SD33T (1985): Change oil pan gasket
Hi everybody,
I live in Germany and own an 1985 Patrol 160 (MQ) long wheel base with the SD33T Turbodiesel engine. Since there are only few old Patrols in Germany, here is nobody to answer my technical questions. I hope that I find more expertise in Australia!
Actually my Patrol's oil pan gasket is leaking. So I have to change the gasket.
Simple question: Is it possible to remove the oil pan without any other actions (e.g. lifting the engine, unmount steering linkage...)
Thank you very much!
15th August 2019 07:38 PM
