ZD30DDTi Rocker Cover Removal and Gasket Replacement
Ok no worries. Guessing it will be easiest to remove intake and throttle body to make taking injector lines off the pump easier?
I honestly can't remember if that will be easier or not. Removing the entire intake is a big job. Get yourself a Gregory's manual, and/ or, download the pdf here. It will explain a lot for you. The Gregory's manuals are quite in depth too.
