Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: ZD30DDTi Rocker Cover Removal and Gasket Replacement
    461 Post(s)
    Quote Originally Posted by Trav_1980 View Post
    Ok no worries. Guessing it will be easiest to remove intake and throttle body to make taking injector lines off the pump easier?
    I honestly can't remember if that will be easier or not. Removing the entire intake is a big job. Get yourself a Gregory's manual, and/ or, download the pdf here. It will explain a lot for you. The Gregory's manuals are quite in depth too.
    Advanced Trav_1980's Avatar
    Feb 2019
    Albany,WA
    Yeah got the online version yesterday and had a squiz at it, not sure whether or not to have a crack myself or just book into Nissan. They're the experts and they have warranty on repairs if it goes south.
  4. #23
    461 Post(s)
    Get a quote from them, theres a few hours in this, it might get a bit exy. If your good with the spanners and have the time, you can do it yourself no issues. Like i said, take plenty of pics as you go.
    Trav_1980 (19th August 2019)
  6. #24
    Feb 2019
    Albany,WA
    Wicked advise, cheers muchly!
  7. The Following User Says Thank You to Trav_1980 For This Useful Post:
    mudski (20th August 2019)
  8. #25
    Feb 2019
    Albany,WA
    Anyone changed out their Injector Stem Seals without using a bit of sealant goo around the outside edge? Just wondering if that will help or hinder the sealing process
