11th August 2019, 10:25 PM
Fridge Slide install to already homemade draw unit
Hi Guys, just fitted my fridge slide to my already homemade draw unit in the GU patrol. as you can see in pic's regards Alex
11th August 2019 10:25 PM
11th August 2019, 10:29 PM
then I added some side support rails so I mount the cut out top piece for the fridge side.
11th August 2019, 10:38 PM
The draw that I removed , I cut in half and works as it did before but half the space lol
with some prettying up e.g. trim and black spray paint.
11th August 2019, 10:41 PM
Here's the final to the working fridge slide that holds my 55 litre fridge
The Following 6 Users Say Thank You to altech For This Useful Post:
MB (12th August 2019), mudski (12th August 2019), PeeBee (12th August 2019), rusty_nail (12th August 2019), SamIam (4th April 2021), Touses (12th August 2019)
12th August 2019, 07:58 AM
You are very handy and talented guy - looks great, keep up the good work, always keen to see a new idea.
altech (12th August 2019)
12th August 2019, 08:18 AM
Nice one. Great job retro fitting it to the existing drawers.
Thanks for sharing.
The Following User Says Thank You to Cremulator For This Useful Post:
12th August 2019, 08:23 AM
Top stuff mate. Next to build a cage around the fridge. Then you can pack stuff over and around it and still pull the fridge out.
12th August 2019, 10:05 AM
mudski
not much room to use as the fridge height is at max headroom inside the rear cab, still have the back seat for storage if needed cheers Alex :-)
The Following User Says Thank You to altech For This Useful Post:
