Results 1 to 8 of 8
Thread: Fridge Slide install to already homemade draw unit
    Expert altech's Avatar
    Nov 2011
    Rupanyup, 3388, VIC
    Hi Guys, just fitted my fridge slide to my already homemade draw unit in the GU patrol. as you can see in pic's regards Alex
    97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
    Nov 2011
    Rupanyup, 3388, VIC
    then I added some side support rails so I mount the cut out top piece for the fridge side.
    Nov 2011
    Rupanyup, 3388, VIC
    The draw that I removed , I cut in half and works as it did before but half the space lol
    with some prettying up e.g. trim and black spray paint.
    Nov 2011
    Rupanyup, 3388, VIC
    Here's the final to the working fridge slide that holds my 55 litre fridge
  6. The Following 6 Users Say Thank You to altech For This Useful Post:
    MB (12th August 2019), mudski (12th August 2019), PeeBee (12th August 2019), rusty_nail (12th August 2019), SamIam (4th April 2021), Touses (12th August 2019)
    193 Post(s)
    You are very handy and talented guy - looks great, keep up the good work, always keen to see a new idea.
    altech (12th August 2019)
  9. #6
    Jun 2018
    24 Post(s)
    Nice one. Great job retro fitting it to the existing drawers.
    Thanks for sharing.
  10. The Following User Says Thank You to Cremulator For This Useful Post:
  11. #7
    461 Post(s)
    Top stuff mate. Next to build a cage around the fridge. Then you can pack stuff over and around it and still pull the fridge out.
  13. #8
    Nov 2011
    Rupanyup, 3388, VIC
    not much room to use as the fridge height is at max headroom inside the rear cab, still have the back seat for storage if needed cheers Alex :-)
  14. The Following User Says Thank You to altech For This Useful Post:
