Results 11 to 20 of 35
Thread: TJM winch
    472 Post(s)
    Quote Originally Posted by dpetersen View Post
    Yeah I get that it’s a fair wack higher in price then a lot of the others but I just can’t understand how some of the cheaper ones would have the reliability of say a tjm or warn. Anyway, time will tell!
    You’re on the money mate!
    Reliability is key, nothing worse than loosing a beloved truck and or worse to a few somewhat dollars in the grand scale relative savings!
    Recovery gear by definition I believe needs to work safely at all times
    Stick around, @MudRunnerTD will help pimp your TJM :-)
    dpetersen (20th August 2019)
    Expert dpetersen's Avatar
    Jan 2015
    Watarrka National Park
    6 Post(s)
    Thanks MB, sounds good!!
    2006 4.2 tdi wagon
    Plenty more to come!
  5. The Following User Says Thank You to dpetersen For This Useful Post:
    MB (20th August 2019)
  6. #13
    Just looked at getting a replacement for my Aldi winch. It runs great but the brake has never worked. I can get a TJM 9500 locally for $1300, but I am a bit concerned that water ingress might not be covered by the warranty.
    https://4x4earth.com/forum/index.php...max-etc.25959/
    Unless it has been updated since that was posted.
    The Aldi one I bought secondhand had already suffered water damage, but it only took a couple of hours to repair it. I also added a silicon seal, which works well.
    Has anyone used a cheaper winch in anger? What were the results?
  7. #14
    Just got off the phone with Sherpa, and their winches are covered for 5 years and it also covers water ingress.
  8. The Following 2 Users Say Thank You to mudnut For This Useful Post:
    jay see (4th October 2019), MB (4th October 2019)
  9. #15
    Jan 2015
    6 Post(s)
    What was the Sherpa worth? I got the tjm 12000 pound fitted the other day, they did a pretty neat job, haven’t had a chance to use it yet. Comes with both the wired controller and wireless. Only thing that’s a bit annoying is that the isolator is under the bonnet, was hoping for a switch in the cab but it’s all good! I think the warranty is only two years though.
    2006 4.2 tdi wagon
  10. The Following User Says Thank You to dpetersen For This Useful Post:
  11. #16
  12. #17
    472 Post(s)
    Unfortunately can’t performance wise comment on our Sherpa as yet. Purchased a 17,000lb twin motor Mule for the back of a ute to hopefully help haul up dead drivetrain Landcruiser mates :-)
    Awaiting installation to come although can say its warranty written and truly excellent customer sales service queries throughout the buying process were impeccable
    mudnut (4th October 2019)
  14. #18
    Interesting that the dyneema slips on the spool enough to tear out fittings on a few winches that were tested.
    https://www.whichcar.com.au/gear/rec...olt-winch-test
  15. The Following User Says Thank You to mudnut For This Useful Post:
  16. #19
    472 Post(s)
    Little help please Craig mate, which linky one suffers that?
  17. #20
    472 Post(s)
    TJM winch
    Cheers Craigstar!
    I’d personally be more worried about the motors and gears on cheaper unsupported ones.
    Pretty sure IIRC bought one for a work ute being the very first original opening in Australia day ALdi’s and found it had absolutely no brake, seriously:-)
    EDIT: Killed a $250 then battery trying to hold a DX on a slope :-)
  18. The Following User Says Thank You to MB For This Useful Post:
    mudnut (5th October 2019)
