Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: TJM winch
    Expert dpetersen's Avatar
    Jan 2015
    Watarrka National Park
    6 Post(s)
    TJM winch
    Hey fellas, had a search but can’t find much info.
    Got the 4wd show on here in Melbourne next week and iv been saving/planning to purchase a winch. Iv budgeted around $1500 for it plus install so I’m leaning towards the TJM torq 12000 pound. Still unsure as to why everything’s measured in pounds haha.
    Anyway has anyone got any positive or negative feedback on them or any other opinions?
    Hoping to pick up a few good deals while I’m there, was hoping to grab a set of poly airs for the rear and possibly the front too, bash plate, couple of uhf ariels, maybe even an on board air compressor depending prices!
    Any feed back is greatly appreciated!
    2006 4.2 tdi wagon
    TJM BullBar and bar work, Light bar & spotlights, Airtech snorkel, tradie rack, blocked egr, 2inch lift on 33s and a 3 inch exhaust to go with it all.
    Plenty more to come!
    194 Post(s)
    That sounds like a lot of money for a generic 12000lb low mount winch to be honest. Have you considered the Runva or even the 4WD super centre units? My brother and his son both purchased the 12000lb low-mounts for about $450 each and they are pretty robust, fully waterproof and simply work. Just a thought.
    dpetersen (11th August 2019)
    Yeah that's crazy money as PeeBee said.
    Carbon winches have been getting a really good wrap lately as well.
  6. The Following User Says Thank You to Winnie For This Useful Post:
  7. #4
    Jan 2015
    6 Post(s)
    Thanks fellas, the main thing I’m worried about is reliability of the cheaper units. I understand it’s important to check them before a trip and what not but prior to living in melb I was in central aus for seven years and the reality is it’s a pretty harsh environment up there and I’m not sure the cheaper ones would last. If I do move back there and a winch fails it could spell a lot of trouble. Just my thoughts but I appreciate the input.
    2006 4.2 tdi wagon
  8. #5
    194 Post(s)
    I think the quality has improved to be honest. Years ago I purchase a 12000lb electric ex USA from Milemarker. Cost a bomb to get it here lots of hype etc, turned out to be the same series of winch brought out by Aldi and TJM and others. It wasn't water tight, but you could fill it with water and mud, then it stopped, but a simple strip and reassemble and off it went again. I ended up sealing it up - and its still going - actually sitting on the floor of the garage to refit to my brothers hilux as a rear winch. To be honest, you need to cycle the winch every couple of months until the motor feels warm to touch and then you should be fine. If you let it sit, as many of us do for 5 yrs then go to use it in anger, and it won't work - all of a sudden the winch is crap - nup, its simple preventative maintenance and the operator has failed.
  9. The Following User Says Thank You to PeeBee For This Useful Post:
    Rossco (19th August 2019)
  10. #6
    Jan 2015
    6 Post(s)
    Purchased the winch today! Original price was $1500 supply only but I got it for $1500 including fitting plus a bash plate supplied and fitted so no complaints here!
    2006 4.2 tdi wagon
  11. The Following 2 Users Say Thank You to dpetersen For This Useful Post:
    MB (20th August 2019), PeeBee (19th August 2019)
  12. #7
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    Quote Originally Posted by dpetersen View Post
    Good result. Bit expensive but I understand they're Australian owned, designed and built. At least your hard earned $ are going back into Australian pockets.
  13. The Following 2 Users Say Thank You to 0-TJ-0 For This Useful Post:
    dpetersen (19th August 2019), MB (20th August 2019)
  14. #8
    Jan 2015
    6 Post(s)
    Yeah I get that it’s a fair wack higher in price then a lot of the others but I just can’t understand how some of the cheaper ones would have the reliability of say a tjm or warn. Anyway, time will tell!
    2006 4.2 tdi wagon
  15. The Following User Says Thank You to dpetersen For This Useful Post:
  16. #9
    472 Post(s)
    Good Stuff
    We’ve still got an old faithful TJM 7,000lb ish on a work Rodeo from well before the turn of the millennium, hand me down unbolt to a top deserved blokes lightish personal Bravo soon it should see another 20+ years with some minor love
  17. The Following User Says Thank You to MB For This Useful Post:
    dpetersen (20th August 2019)
  18. #10
    472 Post(s)
    Nothing against 4WD centres, they’re great for $320ish R&D work!
    $19.99 ish snatch blocks atop of posts as light 100kg pulleys work great :-)
  19. The Following User Says Thank You to MB For This Useful Post:
