Results 1 to 9 of 9
Thread: GQ Tyre width recommendations
    Apr 2019
    89 Mav with 2” suspension lift, I’m looking at putting BFG KM2 33s on, but was wanting to hear others experience of running the wide 12.5’s as opposed to 10.5s on a 15” rim.
    The car is mostly used for bush cruising now, all the fun stuff but not overly extreme, only moderate black top use towing the boat occasionally.
    201 Post(s)
    I prefer the 12.5 for more traction but you do use a bit more fuel for the luxury.
    Sounds like that might not be a big concern for you.
    190 Post(s)
    I bought the 33 x 10.5R 15 because they sat inside the guard flares, were the same width as the factory originals, and give me greater ground pressure than the 12.5" wide tyre. I only use mine in Vic high country though. Still needed to do a minor mod to the factory mudflaps to stop tyre scrub on close to full lock.
    Expert Deano2506's Avatar
    Apr 2017
    Hobart,tasmania
    Have you thought about getting 32/11.5 ?
    I'm getting that size when my current 31s wear out
    190 Post(s)
    Quote Originally Posted by Deano2506 View Post
    I had the Wrangler MTR in 32 x 11.5, great tyre but limited in choice when you destroy one. Still have one here, couldnt sell it even for $50 and it was 200klm old, new $320. I went to 33" and better selection I reckon.
    Apr 2017
    Hobart,tasmania
    Yeah,true.the choices are limited in 32s.
    Good compromise on size though
  8. The Following User Says Thank You to Deano2506 For This Useful Post:
    PeeBee (2nd April 2019)
  9. #7
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    I run 33 10.5 15's... works fine been through sand mud rocks etc also only needed a small flare, and I didn't need to modify mud flaps with 2 inch lift.
  10. #8
    Jul 2016
    i run federal 33x12.5x15 on my GQ with nearly zero scrub and bushranger 75mm flexi flares.
  11. #9
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    33 X 12.5 first set BFG and now second set maxxis razr same size but thinking of reducing the width on the next set .
