Results 1 to 3 of 3
Thread: zd30 neo di injector pump vp44 16700VG100
    Aug 2019
    hi
    can anyone help with the injector pump im trying to find out if an early Y2000 model zd30 neo di with a VP44 16700VG100 zexel 109342-4025 can take a newer model vp44 16700VG100 pump, are the pumps compatible through the year range of the zd30 direct injection engine or not there are quite a few 2004,2005 model injector pumps on the market they are vp44 16700VG100 pumps they have different zexel numbers will they work on an early zd30 DDTI neo di
    thanks for your time
    haide
    Advanced
    Jan 2017
    Hi , I just replaced IP. The same numbers you quoted. When I got home with shiny new pump in sealed bag, I opened the bag and by chance checked numbers. The tag on the bag finnished -4025 same as pump in the bag. But the numbers on my old pump {exchange ] finished -4026.
    I rang the supplier and they said no worries as long as it was -402something , the final number was i think the yr of manufacture.
    Fitted the pump, runs like a dream.
    Advanced
    Jan 2017
    Not sure but when talking to supplier I got the drift numbers could be a little different, but then you need to reprogram the computer?
