Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Td42 on a Y61 blowing black smoke..
    Mar 2011
    Khartoum - Sudan
    Hello folks..
    What does it mean blowing black smoke from exhaust. Specially when A/C is on? Took to a diesel repare shop had my feul pump checked as well as the injector nozzles clean. Still same problem.
    Now started to see slight smoke blowing from cylinder head when opening oil inlet cover. Thanks
    P.S. eats diesel like crazy.
    330 Post(s)
    Needs a tune from someone that knows what they are doing. Black smoke is over fueling, someone has turned the fuel delivery screw up. Turn it back or down. If it's a turbo then you could turn up the boost will help a lot. Watch your exhaust temps too.
    Mar 2011
    Khartoum - Sudan
    Thanks MudRunnerTD.
    What about "Now started to see slight smoke blowing from cylinder head when opening oil inlet cover."
    330 Post(s)
    Likely a little blow by. How many kms on the engine?
  6. #5
    Mar 2011
    Khartoum - Sudan
    Can't really tell as it is a replacement for a Zd30.. But went test on the ground this smoke was not there.. Want to make sure it's nothing much to worry about for now.
    Wail.
  7. #6
    The master farter
    mudski's Avatar
    462 Post(s)
    I would be taking it to a different shop for another opinion. Get a compression test done on each cylinder while your at it. It could just be bad fuel too. Turbo failing. Do you know how much boost the turbo is making?
  8. #7
    330 Post(s)
    He is in Sudan so im thinking he is on his own.
  9. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    mudski (7th August 2019)
  10. #8
    The master farter
    mudski's Avatar
    462 Post(s)
    Maybe not. Google the city. Its pretty big. Population of over 3.5mil. Anyway. Surely theres more than one place. Im not convinced the shop he took it too is correct.
    For the OP. Install a boost gauge and see what the boost is reading. It could just be a simple a too low boost pressure. More info would help. If possible...
  11. The Following User Says Thank You to mudski For This Useful Post:
    MudRunnerTD (7th August 2019)
  12. #9
    472 Post(s)
    Nuffy me, does old mate above have a turbo or just IP screwed up and stinky @mudski @MudRunnerTD mates?
  14. #10
    The master farter
    mudski's Avatar
    462 Post(s)
    Haha yeah I just assumed it got a snail hanging of it. It’s it’s NA, not sure. Could be a block air filter...
  15. The Following User Says Thank You to mudski For This Useful Post:
    MB (7th August 2019)
