Results 1 to 10 of 10
Thread: ZD30 Replaced IP , Pistons hitting valves ?
    Jan 2017
    Help please, I am now raising my voice to my wife,,,, and she doesnt deserve that.
    Removed IP
    Didnt mark anything.
    Forgot to lock scissor gear, but got it reset and the 6mm bolt in and firm.
    OK so now I have C CC marks lined up, all looks good. [ this seems to now be at BDC ]
    Installed IP Put 6mm screwdriver through gear and into IP at 12 oclock. Fitted sprocket onto IP gear, carefully fitted dowel into hole. secured 4 bolts.
    I think now IP is timed to crankshaft ??
    Turned camshafts until A AA and B BB are aligned
    Holding chain with cam sproket two dots on two dark links , fit yellow link onto dimple mark on IP sproket. lot of giggling and minor crank movement.
    OK C CC almost aligned , had to turn crank !/2 tooth to stop interfering with valves [ C CC marks were move 1/2 tooth down towards the grownd ]
    Yellow link on dimple , two dark links on two dimples.
    Removed lock bolt from scissor gear . Turn the engine about 1/2 turn and i feel piston hit valves.
    When C CC marks line up No1 seems to be at BDC , This seems strange to me? If I turn the engine to TDC dimple for yellow link is not anywhere near 9oclock where all pictures seem to place it/
    HONEY I TOLD YOU I JUST DONT FN KNOW
    Help please
    465 Post(s)
    Hmm yeah. I leave this stuff to the experts. I get nervous with this stuff. Good luck mate.
    Sep 2018
    queensland
    wish i could help, i can look in the workshop manual, would need to know if its zd30 di or crd
    Jan 2017
    2004 ZD30 direct inj.
    Sep 2018
    queensland
    so in the workshop manual there alot of info
    if you can get to it it might help.
    go to em and look for zd engine
    or give me your email and i can email you the pdf of just that section
    see the image bellow that might help?
    trying to figure out what stage your at
  7. The Following 2 Users Say Thank You to Fireblade For This Useful Post:
    mudski (6th August 2019), PeeBee (7th August 2019)
    Sep 2018
    queensland
  9. The Following 2 Users Say Thank You to Fireblade For This Useful Post:
  10. #7
    Jan 2017
    Thanks fireblade, I will keep you informed
  11. #8
    Jan 2017
    Decided the only thing to do was remove gear cover and start from scratch.
    Thanks fireblade for first diag.
    V BIG job and tricky, to remove gear cover it was neccessary to remove Wpump studs and make top of the cover move forwards until cover is at nearly 45 deg. to get it out.
    Locked and removed scissor/ idler gear, retimed all gears.
    Reassembled and big relief,,, it started.
    Yaay
    Sorry for being such a grump HONEY, let me take you out for dinner. ....... what and wash the dishes, vacuum, and what?
  12. The Following User Says Thank You to Dagwill For This Useful Post:
    PeeBee (9th August 2019)
  13. #9
    Apr 2020
    Dagwill
    I’m in the same boat as you now. How much of a headache was it to fix this problem? Any little bit of info would be helpful
  14. #10
    Jan 2017
    Hi Shags13, havnt been on here for a bit, so maybe you have already fixed your prob. When you say your in the same boat, what is your actual prob at the moment. Im happy to help if im not too late.
