Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: NIssan Patrol ZD30 Y61 Diesel 2003 model
    Aug 2019
    HI I thought I will update everyone on this intermittent problem. A lot of mechanics had a look at this and said it was the injector pump - were 90% sure despite there being no fault codes.. However after fiddling with the cabling to the Injection pump and the Solenoid on it , the problem dissappeared. I dont know if it will re-appear but have run it a bit and not encountered this. I changed the Cable connector of the injector pump but subsequently replaced it with the original cable . It does look like the vibrations from running it can make the connections intermittent and cause this. Aside from that the only thing that was changed was the battery and a clean up of the Injector pump solenoi terminals.
  2. The Following User Says Thank You to chan For This Useful Post:
    mudski (24th September 2019)
    The master farter
    mudski's Avatar
    462 Post(s)
    That’s a win! Saved yourself a few grand.
Tags for this Thread
