Results 1 to 4 of 4
Thread: What wire to use for td42 fuel cut solenoid after swap from tb42 efi.
    Jun 2019
    Hey all,
    I hot wired my td42 fuel cut but cant find a suitable wire to use from the tb42e loom. I have found some wires that are supposedly hot in 'on' and 'start' but they dont seem to be enought grunt to switch the solenoid. Any advice from people who may have done this swap?
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    Use the wires you found to run a relay.
    193 Post(s)
    Have you tested them or just assuming? Can't imagine the solenoid would draw much at all, mine is a conversion fromTB and used a wire from the carby somewhere, is a small wire but works fine. .
    Jun 2019
    Yeah I tested them, found a wire that was near the injector wires for the tb42 that was outputting 12V when on and start but wasnt enough to switch the solenoid. Ended up using a wire from the coil on the otherside of the engine bay.
  6. The Following User Says Thank You to Auspecial For This Useful Post:
    Rossco (2nd August 2019)
