Results 1 to 3 of 3
Thread: Starter Issue
    Jun 2019
    Starter Issue
    Hey all,
    I recently did a tb42e to td42 swap on my GQ patrol and I am having some starter motor issues. I have the 'B' terminal wired directly to the battery, the 'M' terminal goes from the magnetic switch to the starter body, and the 'S' terminal goes to a black and yellow wire.
    With the key off I see 12V on the B terminal and 9V on the S terminal which seems strange to me.
    Then with the key trying to start I see the same but the S terminal goes to 11V.
    I never see any voltage on the M terminal.
    When I try and start it the magnetic switch gets very warm but no action from the starter at all.
    Any thoughts would be greatly appreciated.
    Expert 0-TJ-0's Avatar
    Jan 2017
    South Australia
    6 Post(s)
    S should see 12v at start. Try feeding this with a direct 12v signal to test it. (jump it straight to B and it should fire).
    If that fails hit it with a bigger hammer.
    Seriously, have someone bash it with a hammer when you try start it.
    Jun 2019
    Never mind I am a moron and had the wires attached incorrectly, glad I had a tb42 starter to have a look at as I was convinced I needed a new magnetic switch.
