Results 1 to 7 of 7
Thread: Delay in power
    Dec 2013
    Dordogne, France.
    Delay in power
    When driving up in to the Pyrenees I was experiencing a delay in power after slowing for an hairpin bend and accelerating after coming out of it. The car was not dying but just holding it's low power state, after some seconds the power returned. What can I do to rectify this problem?
    Dec 2013
    Dordogne, France.
    Sorry, forgot to mention I have a 3.0l Patrol GR auto
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    Could be anything from a bad earth, bad connection or a wire that has rubbed through. You will have to check the wiring loom, especially at the engine sensors. Run a new earth to the block and chassis and clean and tighten the existing earths. After that try and replicate the conditions that caused the fault.
    Was it low on fuel at the time it failed?
    Dec 2013
    Dordogne, France.
    No not low on fuel, it just wouldn't pull for a couple of seconds. Could it be a slow turbo spool up?
  6. #5
    Jul 2015
    Camden NSW
    6 Post(s)
    If it's lifted, it could be the traction control system kicking in and reducing the power. Not sure if your model has it, but if so, and this is the issue, it will usually happen in bends or coming out of them. My 2014 Y61 suffers from this and I have not been able to remedy it, so I just switch it off every time I start the truck.
  7. The Following 2 Users Say Thank You to bazzaboy For This Useful Post:
    mudnut (28th July 2019), PeeBee (28th July 2019)
  8. #6
    Dec 2013
    Dordogne, France.
    Looks like it’s sorted, I checked the air filter and it looked Yuk. Popped in a new one and hey presto the power jump up.
    A good service is on the horizon👍
  9. The Following User Says Thank You to Boyo For This Useful Post:
    mudnut (15th December 2019)
  10. #7
    Dec 2013
    Dordogne, France.
    Apologies for being so late in replying with the result, will try harder in future👍
