Results 1 to 10 of 11
Thread: Engine stuck to bellhousing
    Jun 2019
    Hey all, currently pulling out my td42 to put it in a clean body, I have removed all the bellhousing bolts and have the engine supported on the crane but cant seem to break it free from the bellhousing, any tips for on best practice to break it free?
    @Winnie @Rossco @matfew was there any hidden nuts that we needed to find to split the box of the engine?
    192 Post(s)
    Yeah shouldn't be too tricky hopefully, as long as all bolts undone. Do a final thorough check double make sure you got them all then try a pry bar wherever you can get something in probably the little drain at bottom of bell housing for a start? Might just need a wiggle off ther dowels or break any gasket goo if its been apart before. .
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    When i did my clutch my belhousing was was stuck (more like welded) to a locating stud on the passenger side of the housing. I don't know if anyone has any tricks i should have known about but i reckon it took me longer to get that apart than the entire rest of the operation. Hours I spent levering, jiggling, banging and swearing at the bloody thing.
    Got it eventually but it wss just very, very painful. Hopefully this isn't your issue..
    Hmm yeah I didn't have any dramas with that. Should be pretty straight forward. There aren't any hidden bolts, they should all be really obvious.
    Expert altech's Avatar
    Nov 2011
    Rupanyup, 3388, VIC
    tap the housing with bloody big hammer lol
    97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
    Jun 2019
    Finally got it off, thanks all. Turns out the trick was pressing in the clutch. Unfortunately now the engine wont clear the front of the vehicle with the crane maxed out and the tyres let down.
    What do you all think of taking the springs and shocks out of the car and lowering the body all the way down?
  9. The Following User Says Thank You to Auspecial For This Useful Post:
    0-TJ-0 (22nd July 2019)
  10. #8
    Yeah that sounds like the best option to be honest. I don't see a problem with it.
  11. #9
    194 Post(s)
    What about taking the wheels off and chocking the diff up instead, configure it so the disks are just off the ground - then you only have to jack it back up and put the wheels on.
  12. #10
    Quote Originally Posted by Auspecial View Post
    Take the front wheels off mate
  13. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    mudski (23rd July 2019), Rossco (23rd July 2019)
