Results 1 to 6 of 6
Thread: Talking about GVM
    Expert First Pooy's Avatar
    Mar 2018
    Talking about GVM
    According to Red book my 92 Td42 Gq is 3150 kg GVM which would mean that I am in a bit if trouble because my weigh bridge came back as 2.9 tonnes and I am not fully loaded yet
    462 Post(s)
    It says what your GVM is on the ID plate. Mines been upgraded to 3050kg and I weigh this with just me and empty tanks. Lol.
    MB (12th July 2019)
    472 Post(s)
    G’day Mark, did you mean GU upgraded to 3,500kg mate? Little confused myself family GU wagon stock @3,040kg. Years ago before under the microscope western blokes were upping wagons to 3,500kg with some mods lightly done.
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    My 2001 GU 4500 Ti had a factory GVM of 2960 kg stamped on the VIN plate. I had it upgraded to 3550 kg last year.
    I had to fit specific Toughdog springs & shocks and 2 degree castor correction. Strangely enough, I also had to change the side indicators to cat 6.
    The main criteria dictated by the engineer was that the vehicle had to be diesel, didn’t matter that it was a conversion, and had to have ABS which the Ti has from factory.
    I was allowed to do all the work myself and the engineer came to my place to inspect and fit the blue plate.
    Suspension parts cost $1500 odd and engineer was $650.
    It’s the Toughdog 50mm lift but sits at around 80mm unladen. The rear springs are 500 kg rated.
    The coil tower braces were not required but I had already fitted the Boss braces anyway.
    John
  7. The Following User Says Thank You to jff45 For This Useful Post:
    MB (12th July 2019)
  8. #5
    Mar 2018
    Well I am screwed I don't have ABS and just found out that my Gross is 2.8 tonne and I am at 2.9 and it is not fully loaded yet wtf why so low,I read that Gqs are 3150 kg gross
  9. #6
    462 Post(s)
    Nah MB. Mine was originally 2850kg on the GVM. Being a ZD originally. I was upgraded when I removed the rear seats.
    MB (14th July 2019)
