Results 1 to 1 of 1
Thread: Fix GU patrol 2.8 tdei rocker cover cracking
    Found a way to fix rocker cover cracking on 2.8 tdei Nissan GU Patrol First Remove vacuum pump make plate to cover pump hole or replace cover with earlier model that does not have pump on top.Now fit v6 commodore 12 volt vacuum pump(Brake) and problem solved No more leaks
  2. The Following User Says Thank You to saltfly For This Useful Post:
    mudski (16th July 2019)
