Results 1 to 3 of 3
Thread: 2” lift advice
    Jun 2019
    2” lift advice
    G’day everyone,
    Picked up my first patrol a few weeks back, it’s a 1990 GQ TD42 turbo,
    Suspension will be my first upgrade and after reading heaps of threads about brands and set ups I think I’ve finally got it worked out but keen to get a few more opinions before I start,
    For shocks thinking Bilstein B6 as haven’t heard anything bad about those yet,
    As for coils was gonna go for EFS with 80-100kg load in the front (I’ve got bull bar, winch and dual batteries) and 50-100kg load in the back as I’ve got a roof rack and tow ball but that’s about it rarely tow a little tinny,
    What’s everyone’s thoughts on these brands and has anyone used them together? Any info would be appreciated
    Cheers,
    Expert altech's Avatar
    Nov 2011
    Rupanyup, 3388, VIC
    2 Post(s)
    Hi JD, far as springs you should go abit more heavy duty, i been using Kings springs for my 2 inch lift and they are great , the link below is where I got them from and many other parts to as you see good prices regards Alex
    https://www.ebay.com.au/itm/King-Spr...4AAOSwj01dGJJy
    https://www.ebay.com.au/itm/Rear-2-5...sAAOSwtPddGIw7
    97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
    Jun 2019
    Thanks for the tips, After having a look at the links you suggested I got onto the king springs catalogue and referenced the part numbers and now I’m a lot more confident in the springs I’ll be getting,
    Gonna go with Rear KDRR-43HD (100-250kg) and Front KDFR-42HHD (100-250kg)
    Has anyone used these in the front? Being the extra heavy duty option does seem excessive but with a steel bull bar, winch, dual batteries plus lights and other bits and pieces my front end is well over the 100kg limit on the heavy duty coils,
Tags for this Thread
