Results 1 to 9 of 9
Thread: GU Drive train vibration
    Expert 1peter's Avatar
    May 2011
    Caboolture QLD
    In another post i mentioned a vibration my truck has got when i take off in 1st gear (auto box 4.5 engine). I have since realized that it only does this when turnig as you take off eg: stopped at an intersection waiting to turn, as i take off and turn the corner there is a slight vibration through the drive train somewhere ?? I spoke to a 4X mechanic and before i could say anything he asked me if it did it when i was turning, when i said yes he said it is normal with GU's and it is because of the limited slip diff. Is this true of other Gu owners on this Forum ?? I am going to get the diff oil changed regardless but i am just curious to see if other owners have the same issue ??
    581 Post(s)
    Quote Originally Posted by 1peter View Post
    Hi mate, does it only do it on tight turns or just any type of turn?
    My first GQ did exactly the same thing. I changed the rear diff oil to Castrol SAFXA (85W140) and never had another problem.
    Tony
    Banned
    Quote Originally Posted by YNOT View Post
    My first GQ did exactly the same thing. I changed the rear diff oil to Castrol SAFXA and never had another problem.
    Tony
    Cheers Tony that just saved me a phone call to ya cos the Mav has just started doing the same thing but only after I've been driving a bit & the Diff has had a chance to warm up..
    I recently changed all the box (5spd) & diff oils using fuocs but since then the box is changing like sh!t & the LSD has started getting grabby in the corners when warmed up......
    Any recommendations for box, transfer & front diff?
    I like Castrol oils, a bit more expensive but I've never had a problem when I've been using them.
    80W90 for gearbox and transfer, LSX90 for the front diff.
    I have seen people use auto trans fluid (like Dexron II) in manuals to improve gearshifts but that was in smaller gearboxes, I don't know that I would like to try that in an older and bigger gearbox like you have.
    Tony
    May 2011
    Caboolture QLD
    AB, usually when making left or right hand turns going around corners and only after stopping or slowing down to almost a stop. I will try YNOT's advice and change the diff oil then see how she goes. Thanks for the feedback.
  8. #7
    May 2011
    Caboolture QLD
    Diff oil is changed and the problem is all but gone.
  9. #8
    581 Post(s)
    Cheers for getting back to the post mate, good to hear!
  10. #9
    May 2011
    Caboolture QLD
    Thanks AB.
