Results 1 to 8 of 8
Thread: What is Standard Ride Height?
    Advanced Trav_1980's Avatar
    Feb 2019
    Albany,WA
    Guys,
    Trying to work out to what extent the GU3 I've just bought has been lifted.
    The vehicle was chopped by Dekkers in SA and a box was built by Wilmax, also in SA to slide on the back. The rear suspension was replaced with airbag only and when the box is on, runs at roughly 50psi, maybe a little more and when I dump the suspension to take the box off, I'm trying to work out where the pressure should sit to attain correct ride height. 40psi FEELS right but there must be a no brainer way to check this.
    Any ideas or help is muchly appreciated!
    194 Post(s)
    @MB you might be able to help with this one I reckon?
  4. The Following User Says Thank You to PeeBee For This Useful Post:
    Trav_1980 (30th June 2019)
    472 Post(s)
    Unfortunately can’t remember mate, do remember what I thought it was got kindly corrected here anyway :-)
  7. #4
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    IMHO it should sit fairly level regardless of the load it is carrying. I would adjust pressure accordingly.
  8. The Following User Says Thank You to BillsGU For This Useful Post:
  9. #5
    Feb 2019
    Albany,WA
    Yeah I thought that too. Just thought there might be a benchmark measurement at a certain point on the vehicle that might be a starting point. Given the vehicle has also been lifted as well, not sure how much exactly, I'm also trying to ascertain if the incorrect ride height will affect things like the caster which would directly affect when the death wobbles occur or not. The wobbles dont seem to be taking hold at this point but I dont really know much about the vehicles history either. Still feeling things out at this point.
  10. #6
    Jun 2018
    24 Post(s)
    I'm not 100% sure, but when I was researching factory ride height when I bought my 2004 GU III I have these numbers noted down from patrol 4x4.com;
    Front: 555mm from centre of hub to underside of flare
    Rear: 560mm from centre of hub to underside of flare
    The measurements I took from mine were:
    FL 536mm, FR 541mm, RL 556mm, RR 561mm
  11. The Following User Says Thank You to Cremulator For This Useful Post:
    Trav_1980 (6th July 2019)
  12. #7
    Feb 2019
    Albany,WA
    Yeah that's great guys, thanks for the info. Sorry bin a little slow on the replies, work has been cramping my style somewhat. Bit of work to do with this one me thinks.
  13. #8
    Sep 2020
    reply
    Quote Originally Posted by Trav_1980 View Post
    i have been reading this to use the answer to help myself. can you share what your findings are when you are done, thanks.
