Results 1 to 8 of 8
Thread: Sealant for engine oil pressure switch
    Apr 2021
    Brazil
    Hi.
    I need to replace my oil pressure switch (or change from one engine to another, to be more precise). The manual says to use "thread sealant". What product/brand names would be that? Gotta be something oil and temperature resistant I suppose...
    80 Post(s)
    Whether right or not, I usually use a bit of the copper coloured silicone sealant ( the high temperature stuff) for such jobs.
  4. The Following User Says Thank You to mudnut For This Useful Post:
    BrazilianY60 (6th January 2023)
    Apr 2021
    Brazil
    Thank you Mudnut.
    The search string "copper silicone" helped a lot. Found that and other even more appropriate products locally based on that search. Small things provide big help!
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    Teflon tape aka "ceelon" another option.
    1989 LWB 5-Seat, TD42
    Apr 2021
    Brazil
    Teflon tape is what I actually have on my toolbox. Not sure if it goes well with oil and heat, as I usually use it for water pipes and faucets. Ended up finding/buying a product called Tek-Bond 204. Haven't used yet but seems promising.
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    It's good for solvents (including petrol) and up to alcohol-vapour so oil is no prob. Also good for about 300 degrees celcius iirc.
  9. #7
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    you can get thread sealant from most auto parts stores, I got mine from either sca or repco. unsure of the temp rating but it's used with engine/gearbox oil.
    2008 CRD Auto Wagon
  10. #8
    Jan 2023
    Ive allways used the white permatex sealant with no issues
