Page 23 of 54 FirstFirst ... 13212223242533 ... LastLast
Results 221 to 230 of 536
  1. #221
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    Well there ya go, learning every day. I've never touched superchargers so definitely never seen under the petticoat. Interchiller looks like the business. Gunna be a good setup when you've got it all done mate.
  2. The Following 2 Users Say Thank You to 0-TJ-0 For This Useful Post:
    MB (31st January 2020), PeeBee (31st January 2020)
    194 Post(s)
    I think so too, its been a journey all right and sort of the more you do the more you understand the areas that can be optimised. I am after longevity and a solid package, which is what I should get. I didn't know anything about s/c before I started, and still have a lot to learn as diesel applications have not been as developed or optimised as the petrol variants. I read the books and ask the questions, its all knowledge.
  5. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    0-TJ-0 (31st January 2020), MB (31st January 2020)
  6. #223
    How long until the next weekend away Phil?
  7. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    MB (31st January 2020), PeeBee (1st February 2020)
  8. #224
    472 Post(s)
    Be weary of the cheek old head young shoulders :-)
    Bags first for a Yonk outa the soft stuff from the screws
  9. #225
    194 Post(s)
    Chris,
    in reality I could be out in it now however its still got '8 things' I am trying to sort out, the 3 biggies are the finalisation of the wiring, another 3 days I reckon, the total resolution of the Intercooler/interchiller setup and the chassis plating. I will hook into the wiring this break, and swap out the inlet manifold, then its maybe the plating of the chassis next break, so that the end of Feb. The Interchiller is going to be ordered mid feb for alignment with 2nd break, then install it mechanically. I would like to think I can get it actually charged up that third roster but might have to wait until mid March break - assuming everything goes to plan. The second condenser location is going to be a challenge, its 500 x 400 x 10mm thick. Its normally supplied with a1600cfm SPAL pusher fan and sits in front of the radiator. I am running out of space with the oil cooler, factory a/c condensor and fan, the additional 2500cfm elec booster fan takes up a bit of space. I might end up mounting it horizontally above the engine , directly below the bonnet scoop inlet as that hole is huge - but that makes the a/c lines longer and plumbing a pain - just a few more problems. I want it on the road asap, but am not going to rush it like in the past. I want to be at Licola this year - work stuffed me up last year, so it definitely will be done by then. I then want it thru engineering before doing much else, but that will be an easy appointment as I have already opened the dialogue with the assessor and am following his lead.
    So maybe squeeze in a weekend late April/May - will certainly give you the heads up along with the rest of the herd.
  10. The Following User Says Thank You to PeeBee For This Useful Post:
    MB (2nd February 2020)
  11. #226
    194 Post(s)
    No problem, you can be the driver of the tug!
  13. #227
    194 Post(s)
    New manifold went on today, holes didn't line up again, just like the first one, however the belt alignment is now perfect, so will run the 6 rib belt just to confirm then swap out to the 8 rib later. Setting up the temp sensors again and also the redarc low water unit.
    Next job is the chassis plates.
  14. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    MB (4th February 2020), poindexter (4th February 2020)
  15. #228
    194 Post(s)
    Inlet air temp probes 1 and 2 installed and operational, needed to run a 1/8" NPT tap thru a socket - $68 later, two probes sitting nice and proud in the airstream. Have extended the looms on the 2 EGT sensors to get them up near the drivers side pillar, along with the boost gauge. Mounted the Codan NGT handset after making bracket no. 2 - the first one was devoured by the garage monster and will no doubt turn up one day. Short day tomorrow, garage hand back day before returning to site.
    Will have a look at the opportunity for the additional a/c condenser with luck. Took the beast out for a squirt, the 6 rib belts are squealing under hard acceleration, so I think the 8 ribs will be going on pretty soon also.
  16. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    MB (4th February 2020), Rossco (4th February 2020)
  17. #229
    194 Post(s)
    Thought I was getting closer, but the list just grew again.
    Plate chassis
    Low water alarm
    Boost gauge
    Water mist injection
    Aux fuel gauge
    Bulge blowers
    A/c clutch wire
    Windscreen light power
    Shuroo
    Difflock compressor
    Vacuum reservoir
    Vacuum pump
    Codan connect up
    JingPing rear floor
    Interchiller installation
    Surge tank double insulate
    Boost pump wire and speed control
    Install boost pump flow meter
    Swap out 8 rib belt
    Power to roof rack lights
    Weld out front diff brace
    Weld up rear diff brace for model
    Main large compressor and ringmain
    Cel-Fi install
    Bloody hell, I am getting tired of this right now.
  18. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    MB (7th February 2020), MudRunnerTD (27th February 2020)
  19. #230
    472 Post(s)
    Crikey Philstar, you’ll get there Legend!
    If anyone can..........
    https://youtu.be/qztuEucrNBc
  20. The Following 2 Users Say Thank You to MB For This Useful Post:
    PeeBee (7th February 2020), Rossco (7th February 2020)
