Page 30 of 54 FirstFirst ... 20282930313240 ... LastLast
Results 291 to 300 of 536
  1. #291
    194 Post(s)
    Filled the reservoir and test ran the pump on a closed loop back into the tank, bit of grunt there, soft starter as well. shot a 3/4" stream 8m onto the roadway, but of course not a real world test but impressive.
    461 Post(s)
    I think we need to run bets at $10 each to guess the weight of this beast when it’s done. The closest to the mark gets the kitty.
  4. #293
    194 Post(s)
    OK, I don't exactly know how much it weighs, but its been over the scales at 3320 and 3940kg. The 3320kg was for the engineering brake test/GVM upgrade and the 3940 was in semi battle ready config. Fuel tanks would have been full, water tank full, fridge full of grog in order to get actual front and rear axle loads for the spring selection, and 1 was not in the vehicle at time of weighing. Vehicle did not have the s/c or interchiller assy either. The vehicle would not have had the camping gear or full recovery gear or travel tools I carry.
    I would expect a starting weight around 4150kg without me in it, loaded for a weekend away - that's my opening bid - No Driver, but loaded for a weekend trip up the Vic High Country. @mudski, maybe set this up as a new page?
  5. #294
    461 Post(s)
    Just thinking about this, this morning Phil and I probably couldn't could create a betting thread, for legality reasons...
    PeeBee (15th May 2020)
  7. #295
    Live dangerously. 4151kg
  8. The Following 2 Users Say Thank You to mudnut For This Useful Post:
    mudski (15th May 2020), PeeBee (15th May 2020)
  9. #296
    461 Post(s)
    You sure? He's probably remove 100kg in wiring.
  10. The Following 3 Users Say Thank You to mudski For This Useful Post:
    mudnut (15th May 2020), MudRunnerTD (15th May 2020), PeeBee (15th May 2020)
  11. #297
    Mark, Phil has done so much work on it, I bet he's fitted a Brock polariser voodoo unit and an anti gravity device he's already forgotten about.
  12. The Following User Says Thank You to mudnut For This Useful Post:
  13. #298
    I reckon we call it the Tardis!!
  14. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    mudnut (15th May 2020), PeeBee (15th May 2020)
  15. #299
    Its a GQ on the Outside......
  16. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
  17. #300
    194 Post(s)
    Thank You Men for your kind thoughts. Tardis not avail for number plate, just checked
  18. The Following User Says Thank You to PeeBee For This Useful Post:
