Page 53 of 55 FirstFirst ... 3435152535455 LastLast
Results 521 to 530 of 541
Thread: Harrop 2300 supercharger to Optimiser 6500
  1. #521
    194 Post(s)
    Cheers mate, is a bit of a mission. But I'm enjoying getting to know the new car.
    What psi have you got the SC set at? That then compounds to the Turbo yeah? 1 turbo not 2? That's right yeah?
    Just a Harrop 2300 running the 16psi pulley. I would love the twin turbo feed like on the Banks test Motor, but frankly this engine isn't built for that kind of HP. The Banks engine runs twin turbo's into a s/c, and makes around 1200hp.
  2. The Following User Says Thank You to PeeBee For This Useful Post:
    MudRunnerTD (9th January 2022)
    194 Post(s)
    Finger gotta itchy today after 2 weeks in a nightmare project stage so bought a Marks 4x4 hydro booster to go over the Willwoods. Expect a significant braking upgrade moving forward. The barge is still quit heavy despite efforts to trim it down.
  5. The Following 4 Users Say Thank You to PeeBee For This Useful Post:
    Cremulator (21st October 2022), jff45 (18th November 2022), MB (22nd October 2022), Rossco (22nd October 2022)
  6. #523
    Jun 2018
    24 Post(s)
    I will watch this development with curious anticipation!
  7. The Following User Says Thank You to Cremulator For This Useful Post:
    PeeBee (22nd October 2022)
  8. #524
    Apr 2013
    Upper Ferntree Gully
    22 Post(s)
    Hi Pee Bee
    Have you thought about the aux electric pumps capacity to run the steering and the brakes?
    I talked to Ultimate Power Steering, and they said you'd need 12l/m flow and the electric pumps generally provide 3ishl/m, as I looked at replacing the engine driven pump with an electric pump.
  9. #525
    194 Post(s)
    Quote Originally Posted by poindexter View Post
    Hi Pee Bee
    Are you referring to the Astra electric unit I carry as an emerg breakdown device? I am sure it will be fine. I cant see a need for 12L/min thru the power steering system anyway, but no doubt there are others with alternate viewpoints. The amount of liquid volume is actually captive within the system - bit confused by the question to be honest!
  10. #526
    Apr 2013
    22 Post(s)
    Yes, I was referring to the Astra pump. It's not a viewpoint thing, just a flow in l/min thing. Wanting to know if the Astra unit will drive both at the same time. Do you know the specs of the Astra pump?. I'm looking at replacing the engine driven P/S pump with this. They seem readily available and cheap.
  11. #527
    194 Post(s)
    I don't know the specs but there must exist a listing somewhere. I selected it because its used by a lot of people building hotrods and looking to clean up the engine bay. I would assume it would be sufficient. When I looked at the Hydraboost I could not find a mention about system flowrate or capacity. Working on the assumption that the brakes and PS are closed loop, and the amount of fluid required to operate the actuator, I can't see an issue with the standard saginaw pump - I guess the question is the flowrate sufficient to operate or will the PS slowdown or the brakes fade?. If you find the specs on it and the electric I guess you have your answer. I would think if it works for the PS then the pissant amount for the brakes will be fine, again the system is closed loop once filled to the level and oil being incompressible would think it ok. Even 3L/min is a lot of fluid, and its not like its escaping from the loop - anyway thats my 'impression, maybe not the answer? I have not tried my system out, its rigged up with the hoses and its there to get me out of the bush if the saginaw fails, even slowly.
  12. #528
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    If you look at the pressure reserve reservoir on the hydroboost unit it doesn't look like it would hold more than maybe 200 ml considering there's also a piston & spring in the cylinder and it should be good for a couple of brake applications if the pump fails. That suggests it doesn't need a lot for the brakes.
    I saw it was suggested that you might feel the occasional hard spot in the steering when manoeuvring and braking at the same time but I've never felt it with my installation.
    John
  13. The Following User Says Thank You to jff45 For This Useful Post:
    PeeBee (18th November 2022)
  14. #529
    194 Post(s)
    Finished the hydraulic oil cooler assy today, wired up the fan with external switch. Some would say it was satisfying, nah, another PIA job to get to the end point. Sorted out the air compressor setup and just need to do the final fitting sealing. Sorting out the power cable to the rear pod tomorrow, finally worked out how to run the 16mm cable from front to rear without snagging the exhaust manifold.
    Interchiller modified assy with second pump is waiting for the new brass gear pump to arrive, checked the hoses today and they are not crimped, so its simply a piss poor pumping capability of the davies craig unit - another lesson repeated.
    Should be ready to mount the canopy next week and free it from its home of 12 months in Yarra Glen, then commence the wiring to get it ready for operation. Getting closer by the mm every day.
  15. The Following User Says Thank You to PeeBee For This Useful Post:
    poindexter (8th April 2024)
  16. #530
    194 Post(s)
    Rounding back on this conversation, I have had mine on the road now and cannot detect any deficiency in either steering or brakes. The hydroboost over the willwoods is great, very firm and progressive and pulls up far better than anything to date i have had. The Astra remains as the energ backup system, however probably one of those things that will never get used - with luck.
  17. The Following User Says Thank You to PeeBee For This Useful Post:
    jff45 (7th April 2024)
