Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Dash lights wont turn on, ignition does nothing
    Jun 2019
    No couldnt find it any of those, I put power onto one of the wires which turned the engine but now it is just making a solenoid tap which is under the cover next to the battery, anyone know what could be happening there?
    W.A. (wandering aust)
    Quote Originally Posted by UtmostTrickster View Post
    snip.... but now it is just making a solenoid tap which is under the cover next to the battery, anyone know what could be happening there?
    Low Battery or high resistance terminals most likely...
    Turning over the engine won't help unless you can bypass the ignition as well.
    When you cut the siren it will have triggered the anti-tamper side of the Alarm I reckon.
  4. The Following User Says Thank You to the evil twin For This Useful Post:
    0-TJ-0 (22nd June 2019)
  5. #13
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    The quality of the installation of after-market devices varies considerably. Have they used scotch locks to splice wires or have they done a proper job and crimped or soldered the joins?
  6. #14
    472 Post(s)
    Honestly mate, rip the whole aftermarket immobiliser/alarmy thingymebob out and back to stock IMHO ‘electronic nuffy me says’ :-)
    Have had good mates from the burbs trucks let them down hard way out bush from similar 12v shenanigans :-(
  7. The Following User Says Thank You to MB For This Useful Post:
    0-TJ-0 (23rd June 2019)
  8. #15
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    Agreed. If you're just applying power to random ignition wires instead of removing the unit methodically and reconnecting everything how it needs to be you'll cause yourself more dramas.
Tags for this Thread
