19th June 2019, 04:21 PM
Oil cooler for auto trans
Has anyone installed an oil cooler for their 3.0 Di Auto transmission?
How difficult was the job?
19th June 2019 04:21 PM
19th June 2019, 04:24 PM
Don't they already run one through the radiator?
19th June 2019, 05:38 PM
mudski
I was of the belief that was later series. I have the 2002 GU3.
I could be mistaken though so I will go have a closer look.
19th June 2019, 09:27 PM
Mc4by
I will be easy to tell. If you see two steel pipes going into the bottom of the radiator. You have a cooler.
20th June 2019, 07:32 AM
The ZD30 already has a good sized alloy trans fluid cooler. It's roughly twice the size of the factory TB45E trans cooler.
A good addition is a trans fluid temp gauge if you're towing.. or using it a bit harshly.
John
The Following User Says Thank You to jff45 For This Useful Post:
20th June 2019, 05:40 PM
Thanks I can see the pipes so I will stop worrying about not having one.
