Results 1 to 6 of 6
Thread: Oil cooler for auto trans
Hybrid View
    Patrol Freak Mc4by's Avatar
    Oct 2016
    Mandurah W.A.
    7 Post(s)
    Has anyone installed an oil cooler for their 3.0 Di Auto transmission?
    How difficult was the job?
    462 Post(s)
    Don't they already run one through the radiator?
    Oct 2016
    Mandurah W.A.
    7 Post(s)
    I was of the belief that was later series. I have the 2002 GU3.
    I could be mistaken though so I will go have a closer look.
    462 Post(s)
    Quote Originally Posted by Mc4by View Post
    I will be easy to tell. If you see two steel pipes going into the bottom of the radiator. You have a cooler.
    Mc4by (20th June 2019)
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    The ZD30 already has a good sized alloy trans fluid cooler. It's roughly twice the size of the factory TB45E trans cooler.
    A good addition is a trans fluid temp gauge if you're towing.. or using it a bit harshly.
    John
  7. The Following User Says Thank You to jff45 For This Useful Post:
    Oct 2016
    Mandurah W.A.
    7 Post(s)
    Thanks I can see the pipes so I will stop worrying about not having one.
