Results 11 to 20 of 25
Thread: Not sure what this is (catch can?)
    465 Post(s)
    Quote Originally Posted by dpetersen View Post
    Mines a series iv, 4.2 tdi and it’s got one
    Yeah. @Hodge has these tanks on his GUIV.
    Jan 2018
    Same here 2003 td42ti wagon and I have one too.
    Still sad though because successive pumps when car idle it still goes stiffer. I know our clutches are huge and I assume the hydraulic isnt enough but surely theres got to be a better way? lol
  4. The Following User Says Thank You to drgtr For This Useful Post:
    Yeti's Beast (24th June 2019)
  5. #13
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    Quote Originally Posted by drgtr View Post
    Same , my old GU3 ZD has one and my clutch was the same and was worse after installing a single mass clutch. I even replaced all the hydraulics with little improvements
  6. The Following User Says Thank You to Yeti's Beast For This Useful Post:
    drgtr (24th June 2019)
  7. #14
    465 Post(s)
    Why is that sad? There's no need for successive pumps of the clutch or brake pedal unless your bleeding the system. Its normal really, diesels just dont produce the amount of vacuum like a petty motor can. The system works, and works as it was designed too.
    If you want better vacuum, run a GQ alternator with a vac pump which has a vacuum pump on the back of it and then you have two vacuum supplies. Yes you probably wont run out of vacuum with successive pumps but there wont be any real advantage.
    drgtr (25th June 2019)
  9. #15
    Jan 2018
    Offroading, rock climbing, offroading. Clutch in and out. Not a deal breaker but nevertheless.
  10. #16
    Jan 2018
    on a td42ti can I actually do that? Is it a straight bolt on and plug in? lol that would be great
  11. #17
    465 Post(s)
    Ive done all that plenty of times and never run out of vacuum.
    Yeah man. The GQ alternator runs a vac pump on the back of it. Just run this and simply T it in to the vac supply line thats already there.
  13. #18
    Jan 2018
    You sir a legend. Best thing I heard all day. thank you
    because these earlier alternators with the vacuum pump are cheaper too!
  14. #19
    474 Post(s)
    @mudski good mate! Are you sure that a GQ alternator with rear vac pump can bolt onto a GU like our stocky wagon?
    Do have a GQ custom 170amp on my 6.5NA ute up top with vac needed and was hoping to swap it across oneday.
    Chev diesel will get a birfday eventually of serious alt and elecy vacuum.
  15. The Following 2 Users Say Thank You to MB For This Useful Post:
    mudski (25th June 2019), Rossco (26th June 2019)
  16. #20
    465 Post(s)
    Now you got me thinking MB. It was a while back I did see a GU with a GQ alternator on it at JPC's workshop, was a blacktop too. At worst you'd have to use different alternator mounts if needed or are different.
  17. The Following User Says Thank You to mudski For This Useful Post:
    MB (25th June 2019)
