18th June 2019, 02:47 PM
Grind and Clunk sound
Hi I have a 1998 GU patrol 45ltr, when i start driving in the morning after a few minutes i hear a brief grinding followed by a one off clunk coming from underneath then it doesnt happen again for the rest of the journey, does seam to affect anything and only happens again after i have left the vehicle off for a long period iE if i leave it at the station to go to work it will happen once when i start my journey home, if use the car intermittently through the day it only happens once during the initial start. any ideas?
18th June 2019 02:47 PM
18th June 2019, 03:10 PM
Underneath is a big space. Can you define where abouts, front, rear, middle, left or right side etc etc
18th June 2019, 05:07 PM
18th June 2019, 05:08 PM
it actually happens that quickly while driving its hard to tell would say i feel the bump mostly in the middle.
18th June 2019, 05:37 PM
Breadmaker Shaker
Sticky handbrake drum perhaps?
The Following User Says Thank You to Plasnart For This Useful Post:
18th June 2019, 07:34 PM
Plasnart
That was my first thought about it too. I found my handbrake got a little stuck if the vehicle was parked nose downhill.
19th June 2019, 11:23 AM
Thanks Guys,
I left the hand brake off this morning so when i return tonight to drive home i will see if that is the issue..ill keep you posted.
